4020 clutch replacement
fudpucker
03-24-2006 11:04:19
In your opinion waht would a fair price be to replace a clutch (labor only) on a 4020D w/synro transmission? Also, how long should this repair take? Thanks in advance.
Fud
barnrat
03-24-2006 16:26:10
 Re: 4020 clutch replacement in reply to fudpucker, 03-24-2006 11:04:19
G/MAN is pretty well on with time spent to disassemble/reassemble/adjust. I also send the flywheels out to be turned, and that can take 1-4 business days depending on how busy the machine shop is. The last clutch only I did was in an 856, was about $200 in parts, $50 machine shop labor, $250 my labor. Was dropped off at the beginning of the week and took it home at the end of the week.
G/MAN
03-24-2006 13:47:19
Well, the total price is going to be the hours it takes multiplied by the labor rate. Also will depend on what else you want done. I'd definitely recommend replacing the rear seal, etc. Loaders and cabs add time, also. Anybody familiar with the job should be able to split the tractor in an hour or so. Figure a couple hours to tear down the clutch, replace the rear seal, reassemble the clutch. Maybe an hour to adjust it. And a couple hours going back together and to allow for the incidentals that always come up. With no major problems along the way, it shouldn't take over 8-10 hours. Everything goes good and 6 could catch it.
