4020
txfarmer84
03-24-2006 09:30:05
The 4020 we just got has a "front" PTO shaft that is coming out from under the transmission. Can anyone tell me what this was used for, is it rare or not? Also there are two brackets that are mounted on the top of the frame after the radiator and before the engine, any ideas on this. Also the tractor starts with a push button, we want to get it to start with a key. I ahve a wiring diagram for a 4010, will this work, or do I need one for a 4020. Thanks for the help. txfarmer84
wolfman
03-24-2006 18:21:18
 Re: 4020 in reply to txfarmer84, 03-24-2006 09:30:05
I think all 3010-4020's had that PTO in the belly. Back then (early sixties) it was common to have a side mount mower which used that PTO & a pull behind hay conditioner.
Glen in TX
03-24-2006 14:01:29
Just guessing without seeing it but brackets could also be for a basket cotton stripper or front end loader too? JD made some mid mount sickle mowers that could use front PTO and some cotton strippers may have used it also?
G/MAN
03-24-2006 10:58:36
The "mid-PTO" is standard equipment, I believe. The design of the PTO drivetrain in those tractors made it very easy to put one on, so they went ahead and did it. I've seen it used to run chemical pumps when the tractor had saddle tanks on it. The brackets on the frame-rails are likely for a center rockshaft. Used to raise and lower mid-mount cultivators, perhaps?
