I'm pushin' my luck...
farmerboy
03-23-2006 16:47:02
Talked my Father in law into buying a decent brush mower. We figured a twin knife 8 footer would do the trick. Our hillsides get rather steep.
We went over to the local Deere dealer and he had a 6 year old MX10 3pt sitting on the lot. When I expressed interest, Wally about laughed saying the ole 4020 could never handle a 10 foot fully mounted mower. I observed that he has a 4430 sitting there as well. I also mentioned this mower's cash price is about 1300 less than a new 8 footer, which the dealer did not have in stock anyway. I told him the starter brackets and about 4 slab weights should hold the nose down.
Long story slightly shortened, we're gonna demo the MX10. Am I nuts? This mower does weigh 2100 lbs.
JD9295
03-24-2006 18:28:54
 Re: I'm pushin' my luck... in reply to farmerboy, 03-23-2006 16:47:02
I run a 2512 bush hog on my 4020D, no problems
It is a semi mount which i lik better and the 40 carries it fine with 2 slabs. Ive never ran out of power, mowing set aside usually in 4th if my blades arent beat up and knocking the grass down
Youll have no problems with a 10ft mower
Dr.EVIL
03-24-2006 07:20:52
I mowed about 60 acres one summer for the neighbor with His 4020-D pulling His 12 ft JD shredder. I was mowing grass & weeds between knee high & waist high down to 3-6" tall. I was in 2nd & 3rd gear most of the time. Power wasn't THAT big of an issue but if I went too fast (4th or 5th gear) The shredder just knocked the stuff over and didn't mow it off.
Pete/ME
03-24-2006 02:58:55
I put a 7' JD on my 4020 WFE, two slabs/bracket. It's like it wasn't there...no problem. Just bought a new Woods 7' med. duty, $3,200 at the JD dealer.
farmerboy
03-24-2006 06:01:05
 Re: I'm pushin' my luck... in reply to Pete/ME, 03-24-2006 02:58:55
This MX10 is priced at 3K cash. Walley's got 360 acres to care for with 150 in CRP and 40 in production. The rest is pasture and woods. I wanted to try the biggest fully mounted the tractors can handle. In a perfect world, we'd have a 20' batwing for the CRP and an 8' 3pt for the woods.
My biggest concern is getting into some of these gulleys and washouts on the hillside around here. I know the tractor can handle it on tabletop ridges and valleys in burdocks but what about wooded hillsides in multiflora rose? Guess we'll know by next week.
Glen in TX
03-23-2006 17:47:29
Yep, get some weights on front. They also made other brackets and the double stack slab so you can stack the other weights one above each other. I think it will lift it okay as they handled heavy 6 row equipment okay. What does a 7100 planter weigh? Use to pull a 14 ft. drag type Servis shredder with 4020 in cotton and milo stalks but the 4320 pulled it a little better of course.
farmerboy
03-24-2006 06:04:31
 Re: I'm pushin' my luck... in reply to Glen in TX, 03-23-2006 17:47:29
Yeah, I hope it doesn't come to double stacks. We don't have the starter brackets for that. Heck, he doesn't even own any slab weights, I'll hafta borrow them from dad. Dad never uses them anyway. His 4020 is a dedicated wagon hauler and beebops around the farm nekked.
Before I buy starter brackets, I'll use the 4430.
