6030 shift linkage
smurph72
03-23-2006 14:07:25
Can anyone give me tips or instructions on how to adjust the linkage for a 6030?
It won't go into gear..... I'd like to give more details, but it's at Dad's and I haven't been on the tractor in a long time.
I ususally hang out on the Farmall board. Thanks for any information.
dcm
Glen in TX
03-23-2006 15:22:32
 Re: 6030 shift linkage in reply to smurph72, 03-23-2006 14:07:25
If it won't go in gear first check the rods and levers on RH side of trans to be sure something hasn't come loose. One lever on side goes on a splined shaft and other one has a woodruff key. If those aren't being moved with the lever on dash take the dash shroud off and look for missing, worn, broke pins and linkage. It shouldn't never take over 5 lbs. of force to move the shift lever. If you find pins missing replace them and adjust linkage till no end play and only tighten shaft and linkage rods finger tight before tightening jam nuts. Email me if you need pics or more info. You can find the 6030 parts catalog at JD Parts site, click on parts book.
