Tractorman, When comparing the benefits of two 6 volt batteries versus a single 12 volt, ONE MUST COMPARE APPLES TO APPLES N ORANGES TO ORANGES. A single super heavy duty high amp/hr twelve can store MORE energy then two light wimpy low amp/hr sixes HOWEVER two super heavy duty sixes can store more energy then a single light wimply low amp/hr 12..... ..... ... A battery is an energy storage device which stores energy using lead and acid and plates. Generally speaking and assuming similar design and material and construction, THE MORE LEAD AND ACID AND PLATES THE MOST ENERGY STORED. Two batteries in series add the voltages while 2 batteries in paralell adds the amount of available current. Its possible (still depends on battery ratings) that 2 batteries in paralell can supply more instantaneous current, but not supply it as long,,,,, while 2 batteries in series may not supply as much current but can supply it over a longer time period THEREFORE I would consider what a tractor can best use to start!!!!! ! Its my experience on a Diesel they start better if they are cranked over "faster" cuz that causes the compression to build up and the piston crosses TDC under higher heat and compression, while on a gas in cold temperatures they may need cranked a longer time to start. That all being said..... ..... I would likely opt with the super heavy duty high amp/hr and CCA 12 volt batteries on a Diesel versus the two sixes in series BUTTTTT TTTTT TT the amp/hr and CCA ratigns MUST STILL BE CONSIDERED IN THE DECISION. Another disadvanatge of two sixes in series is the extra connections and if one goes bad it hurts the series combination and they are best if matched in sige, age, design etc and if one goes bad you may have to buy two new batteries. This help or cornnnnn fuse you????? ?/ John T
