820 leaking oil around intake
David Hunt
03-22-2006 10:07:06
I have been noticing oil running down from my intake manifold on the diesel engine on my green dash 820. at first i thought it was a head gasket leaking.then i looked further and noticed it is running out of a small hole in the intake just above where it bolts to the head. the hole looks factory but why would there be a hole there? Its on the right side of the tractor.any help would be appreciated. thanx Dave
JDBert
03-22-2006 14:00:58
 Re: 820 leaking oil around intake in reply to David Hunt, 03-22-2006 10:07:06
My pin hole was at the top- so it was not the drain.
buckeye al
03-22-2006 13:58:04
I agree with FIT. That's a weep hole for moisture that condenses in the Pony exhaust as it warms up the intake manifold. If not for this weep hole, water condensing from the Pony exhaust would accumulate and then freeze cracking the outer portion of the intake assembly or possibly crushing the inner restricting air intake to the diesel. Neither one is a desireable situation and should be avoided!
It's kinda like horses. They all have a hole that some gunky stuff comes out of! On the pony start diesels, this is the hole from which that rather expected and normal crud comes outta! The more tired the pony, the nastier the gunk!
David Hunt
03-22-2006 14:06:49
 Re: 820 leaking oil around intake in reply to buckeye al, 03-22-2006 13:58:04
I agree that its probably the pony motor slobbering and the hole is probably some kinda way to let moisture out but i wasnt sure.the hole is perfectly round so it was drilled in there from the factory i believe. the rings are probably bad on the pony because it sure does smoke.
JDBert
03-22-2006 13:08:22
My 820 had a small pin hole in the pony exhaust section of the intake pipe. My pony was in need of a rebuild and sloobered a lot of oil out the exhaust and then little pin hole. Most likely look at the seem where it was welded.
Jeff NwOH
03-22-2006 11:10:45
Not sure if it's the same as my R or not but if the pony exhaust exits around the intake then that is a weep hole for any moisture that would accumulate. My guess is that it is "weeping" pony slobbers. Only cure would be some pony work.
WeirdDeere
03-22-2006 10:48:58
I don't believe there should be any hole in your intake. This would allow it to suck in unfiltered air to the engine. It is most likely a small rust hole. If your tractor has a pony, the oil is most likely from the pony's exhaust, and it is leaking out from your leaky air intake.
You should probably take the intake off, clean it up the best you can, and weld any leaks shut. I had to do this on my 80. It was leaking internally, but not externally like yours.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
F-I-T
03-22-2006 12:01:50
 Re: 820 leaking oil around intake in reply to WeirdDeere, 03-22-2006 10:48:58
Does the 820 intake manifold have an internal heat exchanger like the 70/720/730's do? If so those 70 series have a weep hole on the underside of the outer shell for water to exit, and hopefully allow the inner sleeve to last longer before a rust out. Pony exhaust swirls around between the inner and outer sleeve before it exits via the muffler, so any pony juice that gets there and condenses could well come out of the weep hole in the form of very sooty oil.
If the heat exchanger is not like the 70 series, then forget everything I said.
Frank
WeirdDeere
03-23-2006 01:34:39
 Re: 820 leaking oil around intake in reply to F-I-T, 03-22-2006 12:01:50
Hey Frank,
The 80/820/830/840 intake is basically the same as your description. I had mine off, I swear I saw no drain hole. I coulda missed it but I don't think so?
Brandon
John Deere Diesels
F-I-T
03-23-2006 06:42:52
 Re: 820 leaking oil around intake in reply to WeirdDeere, 03-23-2006 01:34:39
Brandon:
I would look it over real close again, as I think they would have wanted a way for the moisture to get out, unless it can escape around the pony exhaust piping. Also, since they designed the 80 after the 70D, and the 70D exchanger has a hole, I would think there is one in that 80.
Did you see the one on your 70D?
Frank
