720 taper loc
Chatermb
03-21-2006 15:10:16
I am working on a 720 diesel. The crank is in great shape. I think it was replaced at some point in the tractors life as the local machine shop says it needs no work other than to polish it up a bit. However the flywheel is loose. You can make it wiggle on the crank.
I looked through the past posts on taper locks. However there has been no discussion of how difficult it is to machine out the center of the flywheel to take a taper lock. I am located in Canada and it gets expensive to ship a flywheel to a US shop to get the work done so I was wanting to use a local machine shop to do the work. As they have never done this I am wondering what is involved? Anyone got any comments on this procedure?
Thanks for your help on this matter.
Mike M
03-21-2006 19:27:32
 Re: 720 taper loc in reply to Chatermb, 03-21-2006 15:10:16
Find someone with a lathe big enough to hold it and your home free. I took the ring gear off the one I did and chucked it up on that surface. We just used the compound rest set to the proper angle and feed it by hand.
730-LP
03-21-2006 19:12:13
call Allen machine works 423-753-5738 ask for Dave
mjbrown
03-21-2006 16:24:17
I had to put a taper-loc in my 730D. It is not made from a Deere fly wheel. I don't think it would work since the Deere flywheel hub is slotted so the bolts can draw it down tight. The taper loc has a tapered hole in the center to fit over the tapered sleeve that goes on the crank. No slots.
