JD 4010 propane
Warren Kilby
03-21-2006 12:51:25
1963 JD4010 factory propane. Was running a little rough so we put in new plugs, points, condencer, roter and cap. Now it wont fire. Has pretty good spark at plugs. Has propane. Checked fireing order, coil, condencer,timing. Cant even get a pop. Any ideas would be welcome.
Glen in TX
03-21-2006 13:23:40
 Re: JD 4010 propane in reply to Warren Kilby, 03-21-2006 12:51:25
Gap the plugs for a LP tractor at .015". .012"-.018" range will work for plug gap on LPs and will make them run smoother. LP vapor is on and tank full enough? Liquid closed? Air filter clean? Carb linkage stuck? Draw a crisp clean dollar bill through those new points a few times to clean and polish them some. I've seen new points with that grayish oxide coating and they won't fire good till clean. You have a good hot blue spark at plugs? But is it consistent? Make sure the new rotor, plugs, or condenser are good as yes new ones can be bad, not often but does happen so try old ones again if needed.
Larry48
03-21-2006 18:45:44
 Re: JD 4010 propane in reply to Glen in TX, 03-21-2006 13:23:40
Sounds like excellent advice to me, only thing I'd add is....smell the exhaust and see if you smell propane....after you've tried to start it
