B-camshaft
Gene-WI
03-21-2006 07:11:17
The camshaft on my B broke for no apparent reason, any ideas why it would? Went to start it and it made a clunking sound, so I took the cover by the shifter off and pulled the camshaft out, it's broke in two places,on each end. Also found a used cam on e-bay, but it's for a below s/n 201 and mine is above s/n 201 is there any differences in shafts? will it work in mine? Thanks, Gene
Mike M
03-21-2006 10:05:24
 Re: B-camshaft in reply to Gene-WI, 03-21-2006 07:11:17
You want the 201,000 and up cam as it has larger lobes. Very weird it broke,I parted out alot of those in the past and they never really had that problem show up. I had an A once that the governor lever thrust bearing balls fell out and got into the oil pump drive teeth on the cam and broke them.So I'd be checking for those pieces floating around in there ? Something had to break it.
