J.D. 730 GAS
piston
03-21-2006 05:03:18
am putting on a new in an ex. manifold can someone tell me how does the heat riser go if you put the cold side out like you are looking at the tractor manifold side it is closeing. up the maniflod, with hot side out the manifold is open on the inside, i looked at it b-4 i put it on tractor. is it possible for one side carb be closed up no gas come thru the trac. running on one cyc.plug is firing thanks
ChadS
03-21-2006 08:09:58
 Re: J.D. 730 GAS in reply to piston , 03-21-2006 05:03:18
on our 730 gasser, the cold is to the outside of the tractor. You may have one of the jets plugged on one side, since you may have removed the carb, maybe it got turned upside down and some dirt got in it. Try pulling one of the plug wires half off the plug, see if it fires then,, we had that happen, changed the cap, points, wires, and it came out of it. ChadS
piston
03-21-2006 14:15:59
 Re: J.D. 730 GAS in reply to ChadS, 03-21-2006 08:09:58
I THINK YOU ARE RIGHT ABOUT CARB IT WAS TOTALLY GUMMED UP I REMOVED AN CLEANED I GUESS SOME LEFT I CAN SPRAY CLEANER IN IT WILL HIT, I DONT SUPPOSE THE HEAT VAVLE HAS ANYTHING TO DO WITH IT RUNNING ON 1 CYC.BUT I WAS JUST WONDERING HOW IT WAS SUPPOSE GO THANKS YOUR HELP
Mike M
03-21-2006 05:42:54
Cold side the ex. should go up and out through the main part of the manifold that goes around the back.
Hot should block off part of that back passage and divert some of the hot ex. up around the front passage to heat the carb. up.
piston
03-21-2006 14:11:54
 Re: J.D. 730 GAS in reply to Mike M, 03-21-2006 05:42:54
like i said i looked at it ,yes it is as you say ((BUT)DOES THE COLD GO OUT OR TO THE INSIDE OF MOTOR, OR WHICH WAY DO I NEED TURN THE HEAT VAVLE????? ??
Mike M
03-21-2006 19:37:17
 Re: J.D. 730 GAS in reply to piston , 03-21-2006 14:11:54
Whatever setting you want the words go to the outside and there should be a line to match up so you know it's where it needs to be.
If you use this tractor you may want to set it on hot for this weather we are having until it warms up. Our 4020 runs far better when we set the manifold.
