Cylinders on 36 b
CalJim
03-19-2006 22:39:29
Today we pulled the head off a 36 BN we are
restoring. The cylinder diameters taper down
to a smaller diameter about 1 1/2 inches down
from the top. I did not have my bore gauge with
me but bore measures 4 3/8 roughly at the top,
the taper seems to be about 1/16,which would
make the bore dimension 4 1/4 at the piston,
which is what it is supposed to be. There are definitely no sleeves. What do we have here? Thanks CalJim
sgtbull
03-20-2006 05:40:15
 Re: Cylinders on 36 b in reply to CalJim, 03-19-2006 22:39:29
unless i'm mistaken, my B was the same way. I believe the block was intentionally made that way to facilitate putting the pistons in easier, as it kind of "funnels" the rings into place. The top 1/2" or so abrubtly expanded from the 4 1/4" diameter, at a place where the rings never actually came to, so I don't believe it could possibly be worn that much there. You need to get a bore measurement and check for the common "egg shape" bore. (Pistons laying on their sides + gravity you know.) If the bore is a good measurement w/in an inch or so of the top, and not terribly out of round I don't think I'd be too concerned....after all, are you going to go into farming with this thing? As long as it starts and runs well and doesn't smoke, I'd be pretty happy with it. If you intend to do the antique pulling tractor thing with it, you'd have to do a lot more anyway to be even remotely competitive.
