2030 information needed
Le Ligon
10-27-2003 18:16:17
My father is looking to buy a tractor for his small farm. Unfortunately you can't haul round bales with a '50s International Cub.
There is a 2030 up for sale at an upcoming auction with a 145 loader. I'm familiar with Massey's in the 235-245 range and Fords in the 3000-4000 range.
How does this tractor compare in size and capabilities to them?
What should he be on the look out for when he inspects the tractor on the day of sale? Keep in mind he can't pull the tractor apart to inspect it.
Depending on condition, what do these tractors typicaly go for?
Thanks
Le
Daryl
10-28-2003 09:25:01
 Re: 2030 information needed in reply to Le Ligon, 10-27-2003 18:16:17
The American made 2030's were excellent and dependable. My uncle had one made in Germany(?) and he had all kinds of trouble with it. My father bought one new in 1973 and I use it reguarly and it has around 6500 hrs. I saw one sell on ebay last Winter for about $5000. The loader would also make the price $1500-$2000 higher, I would think. Not a lot of bad points to look at other than the normal wear, breaks, engine condition, hydraulics, etc.
MIKE HANLEY
10-27-2003 18:46:14
The 2030 was made from 1972 with a starting serial number of 134 700T. The 1973's started with serial# 157 109T. The 1974 2030 atarted with serial# 187 301T. and the 1975's started with serial# 213 350T. The 2030 was rated at 60 Hp and had a shipping weigth listed at 4800#. Thats shipping weigth without options, added weigths or fluid in the tires. They had 8 speeds foward and 4 revs gears. Low gear was 1.48 MPH at 2500 engine RPM's and 8th gear was 17.26 MPH at 2500 engine RPM's. The engine was a 4 cylinder diesel with a bore ans stroke of 4.02 X 4.33, 219 cu in. Standard tire size was 14.9 X 28. 3PT was CAT II and had a 2" float ajustment in the lift links. The Hdy's are closed center and run the power steering, the 3Pt and the remotes. The transmission, differential and hyd system's use the same oil (10 gals). Live 540 PTO was standard. 540/1000 was optional as was a 1000 RPM mid PTO.
trp6645
09-08-2004 11:10:43
 Re: Re: 2030 information needed in reply to MIKE HANLEY, 10-27-2003 18:46:14
I have a 301-T john deere with serial numbers 139434T. Would you have any ides what size this tractor is? Any info would be greatly appreciated as I am having trouble finding anything on this tractor
