OT Sand Blaster
tsmith1499
03-19-2006 19:43:36
I bought one of those 40lb canister type Clarke pressure blasters at an auction a few weeks ago. I haven"t been able to get this thing to work right yet. Does anyone know the secret? First it will just spew out sand at a low rate and then all of the sudden it will goes all out and work great. Then it will just drop back down again. I have tried differeent nozzle sizes and different types of sand as well as some Black Beauty. All were dry. Help Tom
johns48b
03-21-2006 08:28:30
 Re: OT Sand Blaster in reply to tsmith1499, 03-19-2006 19:43:36
on my blaster i added a long extension to the valve so i could control it standing up and was able to control the flow better. i had a buddy give me a little vibrator that i set down on the screen wire that i filtered the sand through. it made the filtering a lot easier. i used five gallon buckets to pour the sand out of and under the screen too. i didn't fill them but half full and it made it easier to handle. i took the lid off of a bucket and cut the inside out and used screws to fasten the screen wire to the "doughnut" top and it work out real well. those things are awful aggrivating to use unless everything is just right.
Glen in TX
03-20-2006 09:35:30
Agree with others on problems with a mixer valve worn or plugging. Seals and balls in valves wear out. Some like the Marco have their own special mixer valves too. Some valves also have a strainer built in and need to be removed for cleaning and maintainance. A few places for blasters & parts: brutmfg.com marcousa.com blast-it-all.com tptools.com
jubilee johnny
03-20-2006 08:12:33
Any sandblaster will do what you are discribing if the sand is not sifted, the sand is not completely dry, or moisture develops during extended sandblasting sessions. The valve at the bottom will control the amount of sand coming out, but if it gets a moisture problem that valve has to be opened all the way and the bottom plug removed and a long screw driver or stiff wire placed to clean out the blockage. It may be a piece of trash but more often than not it is wet sand. Then you really have to get all that out and sometimes it is frustrating.
CFWeles
03-26-2006 06:22:15
 Re: OT Sand Blaster in reply to jubilee johnny, 03-20-2006 08:12:33
I second that completely. Have a truman 100 pound presure tank setup and it flows perfectly to sand empty if sand is dry. That's the key. Must be completely dry.
Henry M
03-20-2006 04:57:40
I bought one from harbor freight and it works great. I operate it exactly as ET describe.
Initially I thought I would never get the thing to work. finaly I turned it upside down, emptied it, and discovered it had trash in it that was stopping the flow of sand. Also If I blast long and hard, moisture will be a problem because the air gets real hot and the water passed right thru the separator and shows up in the blaster.
I rigged my own strainer out of screen wire and never add media unless it goes thru the strainer.
ET
03-20-2006 04:48:08
It sounds like the valve at the bottom of the tank is worn out. On mine I regulate the air to 90psi from the compressor, a water trap in there is a good thing too. I pressurize the pot first, then I open the air all the way to the blaster hose, and finally I slowly meeter in sand with the mixing valve. Less sand cuts better than too much. I aim the nozzle at my project as I add in the sand to see how its cutting.
tsmith1499
03-19-2006 21:30:25
Thanks Duane, I did not get any directions with this and I thought it was kind of funny that the valve on the bottom didn't shut off the sand or air all the way. Thats what I thought it did. Any hints on which direction does what? what do you use for blasting? I assume you always keep the lever on top after the filter full on all the time while blasting. Thanks, Tom
Duane Larson
03-19-2006 21:05:59
Tom,
My TIP pressurized pot sand blaster has a mixer valve with a lever on the bottom which controls the ratio of air/sand. If that gets changed I have had your symptoms. The proper setting depends on the grade of sand being used.
Wet sand/wet air can also cause your problem, but apparently that is not your case.
RedJD
03-19-2006 20:09:52
Hope someone has a solution to your question.I bought one from Harbor Freight and I have the same problem.
