Adjusting linkage on 4020 synchro?
Nylon
03-19-2006 15:02:17
All the shifting this synchro is pretty loose. Not a problem for most of it but.....the first zone gears 1, 3 and low reverse is hard to get in to that quadrant. It can be done...just isn't smooth. Once in the quadrant getting lined up into 3rd is the most difficult. Reverse and 1st are pretty easy to get into and stay firmly in gear. When I go to use third it had often poped out and did the grind as it drug against the gear it was supposed to be in. I have since discovered that if you get it into 3rd and you dont jam it all the way to the upper stop, it will stay in gear just fine. Often I jam it to the stop like you do in all the other gears and then make certain to back it off just a but and you can almost feel that it has hooked up. Any advice here would be great since the I&T is not worth a dang on this nor is the owners manual.
Thanks,
John
alabamafrog
02-02-2009 15:43:56
 Re: Securing the seat in reply to 2cylinder, 01-28-2009 15:42:37
garytomaszewski said: (quoted from post at 19:43:24 01/28/09) Frog,
I'm going to assume that 80 MPH wind is from driving 55 into a
25 mph wind. LOL
I didn�t think about head winds, I guess I need to find some 110mph Velcro.
I usually try to keep it down near 70 when hauling 2 tractors on the interstate but occasionally might bump 80 when passing.
I might do both the tarp strap and put Velcro around the edges, I could keep the tarp strap in the battery boxes with the pipe covers and try to remember to put it on the seats each time I haul them.
This post was edited by alabamafrog at 15:45:28 02/02/09.
Nylon
03-20-2006 09:36:47
 Re: Adjusting linkage on 4020 synchro? in reply to ET, 03-20-2006 06:43:39
Thanks for the info. That is what I figured. What do you use for the shims to take out play? I didn't know what specific items I needed to look at. Does JD have a "tune up" kit for the synchro or do I need to finds each component. Also, The cone to spring & ball follower....can you do that without opening up the tractor too far?
Thanks for info guys,
John
ET
03-20-2006 11:54:57
 Re: Adjusting linkage on 4020 synchro? in reply to Nylon, 03-20-2006 09:36:47
I use washers under the snap ring on the quadrant. The parts book shows three different thickness washers to use as required. The bushings and fiber thrust washers have to be ordered seprately. The ball and follower goes right in under a plug on the right side of the transmission. The new style detent is the upper one in a 4030 syncro range I think. It has been a while scince I ordered one. You will need the plug, seal washer,spring, follower, and ball. If I remember right the lenth of the spring is different between the upper and lower detent on the 4030.
Mike M
03-20-2006 10:12:19
In addition to all the above to save money and tighten up stuff I have built up the shift lever and gates where worn grooves are with weld and groung back flat.
Nylon
03-20-2006 17:56:53
 Re: Adjusting linkage on 4020 synchro? in reply to Mike M, 03-20-2006 10:12:19
Thanks for the specific info guys. I will do all of the above listed tips.
John
