#44 Plow
BUDD
03-18-2006 04:53:46
I am in need of a "LIFTING SPRING" and the rod for a # 44 plow. Does anyone have any ideas where to get this? If I could get the size of the spring I could adapt one to this plow.
Thanks BUDD
mitchp
03-27-2006 06:08:03
 Re: #44 Plow in reply to BUDD, 03-18-2006 04:53:46
hey bud, i have a 44 plow if you still need the measurements i can look on mine
BUDD
03-18-2006 08:53:38
jdal
I did try John Deere with no luck. The part was obsolet. If I could get the wire size the length and the Dia I could make one work.
BUDD
Glen in TX
03-18-2006 10:29:42
 Re: #44 Plow in reply to BUDD, 03-18-2006 08:53:38
If you have the spring number try again and make sure the parts man left the R or letter off the end. If it comes up at all on JD Parts online then it might show the size of spring? Someone here will have a spring to measure for you.
jdal
03-18-2006 08:16:02
Have you tried JD. I bought a model 51 a few years ago that had a new spring on it with the JD tag still there. Otherwise you might find one on a salvage plow.
