6 Volt vs. 12 Volt
Trigg
03-17-2006 21:18:03
just scored a 1954 40 C for an amazing deal (300.00). It probably needs a new starter and generator. Can anyone tell me if it is better to stay W/ a 6 volt system or convert to 12?
Glen in TX
03-18-2006 10:54:00
 Re: 6 Volt vs. 12 Volt in reply to Trigg, 03-17-2006 21:18:03
I agree with what the others said. If previous owner told you it was 6V probably is but if it turns over real slow it could have already been converted to 12V. Found that out when I got my H it was already converted but not marked or changed on generator tag. The starter may can take 12V as is but probably needs a rebuilt too. For the true 12V conversion starter & generator will need armature and field coils changed. If those are burnt out needing replacement you would be more than half way there switching to 12V. Kenneth at Midlothian TX can advise you on parts replacements or conversions.
John T
03-18-2006 07:00:16
Trigg, I totally agree with Van. If youre gonna actually use it and need to start it at extreme cold temperatures etc., I also would convert her to 12 volts. HOWEVER its my guess its for show and hobby use and to satisfy any "Correct Police" or if originality is of importance, keep her at 6 is also my suggestion. If you do stay at 6, I would still use the biggest heaviest highest Amp/Hr or CCA battery that will physically fit into the battery compartment and use 00 Gauge Battery n Starter n Ground Cables just to be on the conservative side, even though if the engine and ignitioin are in decent shape, she shouldnt be hard to crank even if lesser components were used.
John T
van robinson
03-17-2006 21:55:23
If it is to be a working machine, I would go 12V for ease of cranking, finding batteries, jump starting, etc. For show, i would stay with 6V to keep it as close to original as possible.
My 2 cents.
CPeter
03-18-2006 17:11:57
 Re: 6 Volt vs. 12 Volt in reply to van robinson, 03-17-2006 21:55:23
John T and I rarely disagree, but this is one that I don't agree with him on. I have a 40C 12V (conversion done before I bought it) and a 420U that is 6V. The 420 will start just as easy as the 40 and I use them both to move snow with here in New Hampshire at temps below zero and I run 15w40 Rotella oil in them year round. 12V conversions are a cover up for something that is wrong with the tractor. The tractor needs good 6V cables with good solid connections(not the flimsy 12V jobs from the auto parts store), a good starter,(cost to rebuild is less than $20), a half decent battery (I get mine at Sams Club), and a distributor the has good points and condenser in it and a set of hot spark plugs (I use either Autolite 216 or better yet Champion H12 with 2 gaskets). Try to get the engine hot, either with a set of shutters (you should be so lucky as to find some) or a cover over the grill.
One problem with the 12V conversions on the Dubuque tractors is that the starter will destroy the ring gear because it was not designed to take the much higher hp put out by the starter running of 12V.
