Radiator - JD L
BURT
03-17-2006 10:54:48
Two Questions:
Does anyone know if a radiator off of a LUC will fit an L with a Hercules engine?
Does anyone know of a source for replacement radiators for the L? Mine has a non-standard radiator, which while it works, I would someday like to replace it with an "original".
Thanks!
BURT
03-20-2006 11:48:22
 Re: Radiator - JD L in reply to BURT, 03-17-2006 10:54:48
Thank you two for the replies. I will check into Blaze Tractor Parts and give Rusty Acres a call (he only lists LUC and LA engines on his website). Thanks again.
Mike M
03-17-2006 11:21:58
I would think it may not as I put one from an LUC in an LA and the water inlet and outlets were bigger on the LUC. I could of switched the inlet and outlet castings as the engine blocks are the same. But I was changing the engines anyways.
