4010 power steering problem.
Calvin B. in Be
03-17-2006 06:23:11
Help!!! I am presently trying to restore a 4010 John Deere diesel. It lost it's power steering when I was turning right.Before that happened, when driving on a road at a higher speed, I noticed it drifted to the right & when you go to correct it, it would jerk to the left instead of a smooth action. I pulled the steering valve & found some of the seals/'O' rings out of place. Rebuilt the valve & call myself setting the con-trol valve to the specs. in the shop manual. After installing steering valve, I turned the wheels to full right, open the bleed valve & started engine. No oil came from the bleeder valve. I bled it manually & could turn the wheels fine, but when engine is started, it turns to the left good, but very hard when turning to the right.Repeated the manual bleeding & only got the same results. I am wondering now if it could be the steering motor? I am in desperate need of help.
Thanks Calvin
donmyeil
03-17-2006 13:28:43
 Re: 4010 power steering problem. in reply to Calvin B. in Benton., 03-17-2006 06:23:11
If the valves are not adjusted right it wont work. You have to have an adjusting plate , Also the steering has to be turned to a full right turn and held there with a weight while the valves are adjusted. Not a job for an amature to be sure.
skipp 33652
03-17-2006 09:31:22
I had a problem very simalar several years ago I put new valves in the steering unit and would work one way but not the other had a jd mechanic help me on it after about 5 or 6 assembly disassembly operation I discover in deere infinate wisdom they had changed design of valves( seats and needle?? been awhile) the new valves were pluging oil passages two would work two would not threw two new ones away and put in best used ones in those holes that were being plugged or restricted. not the first time deere and company has screwed me on replacement parts that fit and wear like original probably wont be last either. anyway this sounds like it could be the case. Paul
woodbutcher
03-17-2006 08:31:11
Calvin,
I had a similar problem with my 3010. I don"t know how to rebuild the steering unit, so I ordered a used one from a place in Iowa for $300.
It has worked fine for 5 years.
Butch
woodbutcher
03-17-2006 08:30:46
Calvin,
Butch
Bob
03-17-2006 07:00:57
Have your steering valve rebuilt and set by someone who knows what they're doing.
H2
03-17-2006 08:35:19
 Re: 4010 power steering problem. in reply to Bob, 03-17-2006 07:00:57
I have had the same issue, I had the valve rebuilt by a JD dealer and I am still having issues, although not as bad. Any suggestions would be appreciated.
Bob
03-17-2006 08:48:51
 Re: 4010 power steering problem. in reply to H2, 03-17-2006 08:35:19
I supose there is a small chance of a problem up front, I still think the most likely cause is that something was overlooked when the steering valve was rebuilt.
