3020 12 volt conversion
mikeinWA
03-16-2006 08:21:42
My 3020 was updated to two negative ground, 12 volt batteries. Can someone direct me to a diagram of this wiring. I have a ground fault somewhere.
Mike
Bob
03-16-2006 09:20:16
 Re: 3020 12 volt conversion in reply to mikeinWA, 03-16-2006 08:21:42
Just to clarify this...
Originally 24-Volt diesel 3020, converted to 12-Volt, negative ground 12-Volt system with 2 12-Volt batteries in parallel?
mikeinWA
03-17-2006 09:48:19
 Re: 3020 12 volt conversion in reply to Bob, 03-16-2006 09:20:16
Yes, thats the set up. The left battery has been draining so for the past year I have been pulling the neg. cable after use. When I attach a voltometer between the neg post on batt and the neg cable, with everything off, it reads 10+. Left battery goes directly to starter solenoid. System has starter solenoid and relay. Also updated to single wire alternater. Right hand battery has cutoff on dash. Any help on chasing the fault along with a decent diagram of the original conversion would be enormously helpful.
