4010 Gas or 4020 LPG
rboulware
03-16-2006 07:04:34
I have narrowed down my choice to a 4020 LPG with wide front and 3pt hitch. It has a cab but all the glass is out on it. The price would be $3400.00 delivered to my door step.
OR a 4010 Gas 3 pt hitch Wide front for Maybe around $4,500.00 delivered. This one is simply an OOPEN station. Both of these Machines will be something I see over the net and Email. Which one would you choose and why?
j cook (iowa)
03-16-2006 09:03:41
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 07:04:34
Don't buy anything over 50hp that runs on GASOLINE.
Personally, I wouldn't want anything over even 25hp that ran on gasoline.
Mike M
03-16-2006 09:53:16
 Re: 4010 Gas or 4020 LPG in reply to j cook (iowa), 03-16-2006 09:03:41
I would say it all depends on what you want/need it to do.
We have a 4020 Gas and love it. But it is a loader and blade tractor that sees very limited use. It does lots of starts and stops. I would think this isn't the best for a diesel. Also the colder it gets the better it seems to start.
I have worked it hard at times all day long and it was up to the task when needed. You sure can run alot of gas through one too ! I would not like it very well for serious work because of this alone. The diesels are made for serious work and have more power too. They all have their place.
Jon (IN)
03-16-2006 08:31:07
I have to agree with John. I don"t have any experience with LPG, so I can"t comment on it. As far the gas, I would either go diesel or shop around some more. Not sure how you are going to use the tractor, but I had an Oliver 1850 gas, which is similar sized about 90hp, that I used to brush hog about 60 acres of CRP ground, and just use for other general chores. I used it for about 10 years, and could not wait to get a diesel. When worked these larger tractors use a lot of gas. Price seems high for a gas. I sold my oliver for $3000 and it had a newer overhaul and new tires. Granted the deere will bring a bit more, but gas tractors that size can be had all day long for between $2500 - $3500. Personally, I would never own another tractor over 50 hp that was a gas.
Jon
rboulware
03-16-2006 10:28:51
 Re: 4010 Gas or 4020 LPG in reply to Jon (IN), 03-16-2006 08:31:07
I wished I knew of a 4020 Gas tractor for $3,000.00 or less that I Could Trust the transmision or Rearend. I might jump on it TODAY. But I have not run accros any....most seem to be about $5,800.00 and up...
rboulware
03-16-2006 11:43:00
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 10:28:51
Do you think the Powershifts are more reliable or the syncro transmision
Mike M
03-16-2006 11:08:49
I don't think it's as much an issue if you can trust the tranny as much as it is IF YOU CAN TRUST THE SELLER.
rboulware
03-16-2006 11:41:06
 Re: 4010 Gas or 4020 LPG in reply to Mike M, 03-16-2006 11:08:49
true....SOOO true....but you know, the seller might not know the history either....The transmision could be bad and no one REALLY know it.
Mike M
03-16-2006 12:35:31
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 11:41:06
You won't know for sure until you work it ? But just if it runs and moves in all the gears with no horrible noises it might be enough to assume it's fine. I don't think those had alot of tranny trouble. I think the biggest problem is worn shift linkage and that can cause tranny trouble if the operator doesn't get it in gear all the way. Biggest problem might be if water got in the oil and then the brake linings are gone and the pieces plug up the hyd. screen. When I was looking for one most had engine problems. Which one can just buy a diesel engine from a combine and swap it out if you buy it cheap enough.
rboulware
03-16-2006 13:59:18
 Re: 4010 Gas or 4020 LPG in reply to Mike M, 03-16-2006 12:35:31
That was my plane after using it a year a so, I would repower it with a Diesel. After running like it was I would get enough confidence to repower it...
Jon (IN)
03-16-2006 10:43:30
I know how it is to get the fever.. But I would say to keep looking if you can.. you will come upon one. FWIW, I paid $6000 for my 4020 powershift diesel and it needed nothing. Saw a 4020 Gas sell at an auction about 6 months ago and it brought $3800. My point being, that if you can wait and keep looking, they are out there.
Good luck in whatever you decide....
Jon
rboulware
03-16-2006 11:44:16
 Re: 4010 Gas or 4020 LPG in reply to Jon (IN), 03-16-2006 10:43:30
Jon (IN)
03-16-2006 12:52:39
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 11:44:16
I really researched this before purchasing my Powershift. I don't have a lot of direct experience with them, but can tell you what I gleaned from my research. A strong, well maintained powershift will last a long time, some claim 10,12, even 18,000 hours on one. What sold me on mine was that I watched the trans pressure gauge when shifting through the gears. At anything over 1500 RPM, they trans pressure needle never dropped down much when shifting through the gears. I believe this shows a strong powershift. It has good firm shifts through all the gears at any RPM. Knock on wood, I've not had any problems with mine. and have owned it for a little over a year now. and the tractor has right at 6000 hours on the meter.
Jon (IN)
03-16-2006 13:07:46
 Re: 4010 Gas or 4020 LPG in reply to Jon (IN), 03-16-2006 12:52:39
I had one other thought too... probably not going to be real popular on this forum but here goes anyways. If you are tight on money and you are really looking to buy a tractor quick, I would not be stuck on a JD. They just go for a higher dollar than a comparable machine from another make. That is a two way street though, as when/if you want to sell it, that Deere will bring more. I've wanted a 4020D for a long time, but used an Oliver 1850 for nearly 10 years. It was a good tractor and served me well, but when the opportunity to buy a 4020 at the right price came along, I jumped on it. I think I now have a better tractor, with better resale than I had before. These tractors are just getting too old to know for sure what you are getting. And restricting yourself to one make or model, without putting the time in to really see what you are getting, is just asking for trouble.
Hope this help, or even makes sense, but it's just my $.02
Jon (IN)
rboulware
03-16-2006 14:09:54
 Re: 4010 Gas or 4020 LPG in reply to Jon (IN), 03-16-2006 13:07:46
Your right, I have been looking around. Actually I started out looking at an Allis D19 Gas tractor, but they are KNOWN for Transmision Problems. So I steared cleared of them. Then I started looking at massey 1100, but to come to think of it they were no more cheaper than the JD 4020's really. I would Still consider a Massey 1100 , another thing it sounds like the massey were bigger than the JD 4020's. Which is NOT really a good thing for me. I sort of need a some what big HP with reasonable size tractor. That is sort of why I like the 4010 more than the 4020. they are 1500 pound lighter. Now I REALLY LOVE the CASE tractor but here again they have had a funny history on thier Powershift. So I am sort of stuck back here at John Deere they seem to have the best of EVERY thing, but price. I like Oliver too the 1850 I would LOVE to get one in 4whd though. They seem sort of rare as well. Any ways I am sort of here with ther Deers right now..
R. John Johnson
03-16-2006 07:23:24
Unless you run only a few hours a year, I would chose neither. Get either of those two tractors in a Deisel. You will be much happier. Also I would hestitate to buy a tractor unless you can physically inspect it first.
John
rboulware
03-16-2006 10:31:02
 Re: 4010 Gas or 4020 LPG in reply to R. John Johnson, 03-16-2006 07:23:24
well I will REALLY be only running this on the weekends form any where from 30 minutes to 3 hours. That IF I am in town that Saturday..
rboulware
03-16-2006 11:37:28
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 10:31:02
Man, I did not KNOW a LPG would last longer than a Gasoline tractor...I wish I could post pictures of both these machines. They both are REALLY to far to go drive and see, really. I have to go by the dealers word for it, and sort of hope for the best. This is the WHOLE reason I have been asking SOOOO SOOO many questions on here. Because all the machines are over the internet, and I can't pratically go and see these machines except for photos. I have been looking on places like Machine finder, Iron search, and others as well.
So an LPG last longer than a Gassoline machine right? Well will an LPG last longer than a Diesel?
When I AM useing the tractor, it will be working sort of hard. Bush hogging and running a Harro and a Plow. Really a Hard working General Purpose tracor if you would....any Hoot I do apprieciate your response it is helpfull.
Bob M
03-16-2006 11:06:58
What the others say about diesel over gas is true: If you�re gonna work the tractor long hours a gasser or LPG�s fuel consumption will give you fits.
However if you�re talking 50 � 100 hours a year of generally light duty (which it sounds like you are), you�ll probably never recover the higher initial cost in fuel savings of a diesel tractor over one with a spark ignition engine.
That said, if you do decide to go for one of these 40's and all other things being equal (total hours, general condition, etc) I�d lean toward the 4020 LPG. Reason: LPG engines stay amazingly clean internally and will generally run many more hours before needing an overhaul than will an equivalent gasoline engine. Chances thus are very good the LPG engine is in much better shape than is the gasser.
On the flip side, depending on where you live LPG may be more difficult and costly to get into your tractor�s fuel bottle than is gasoline. Also running out of LPG in the field can be a real PITA - though keeping a 20# gas grille tank and suitable adapter aboard to hook it can pretty much eliminate this problem.
Further cold starting an LPG tractor ("cold" being below about 50 deg or) can be a problem unless you are mindful. But it is easily managed. (We operate an ancient Minnie Mo G LPG, often in temperatures down near 0 degF. As long as it is kept in good in tune and the proper starting procedure is followed, the old Minnie starts easier than it�s gas and diesel cousins.)
A final thought: I�d never purchase ANY tractor sight unseen. I want to see/run it myself. Or at minimum have it thoroughly gone over, test run, etc. by a TRUSTED friend (ie. not by my brother in law, my wife�s hairdresser�s cousin�s next door neighbor�s fishing buddy, etc�)
rboulware
03-16-2006 11:38:21
 Re: 4010 Gas or 4020 LPG in reply to Bob M, 03-16-2006 11:06:58
Bob M
03-16-2006 14:28:57
 Re: 4010 Gas or 4020 LPG in reply to rboulware, 03-16-2006 11:38:21
Once again LPG engines usually last much longer between rebuilds than do gasoline. Reasons: Propane is very clean burning (leaves little acid and other deposits in the oil). Nor does propane wash oil of cylinder walls, dilute the oil, etc like gasoline does. Also it is very knock resistant - propane is much less likely to result in knock damage in an engine operated under constant heavy load.
Will an LPG engine last as long as a diesel? They can, though much depends on the engine design, type of application, maintenance, etc. In fact in in certain applications an LPG engine may actually outlast a diesel.
As for fuel costs, for your situation you'd probably need to run a diesel 1,000 to 1,500 hours before you'd recover the higher initial price in fuel savings. Keep in mind also diesel is currently 20 - 30 cents per gallon MORE than gasoline. This somewhat diminishes the diesel's fuel economy savings advantage.
