Bolt torque and mag question
Ivan in Mich
03-15-2006 17:44:39
Could someone tell me what the bolt torque is on the 2 bolts that hold the rockerer shaft on a 1951 JD B? I have the mag taken apart and I have to replace the bearing on the lug end of the shaft. I would like to know if that nut has left hand threads? When I pull the the cap that has the lugs on off is the spring under it under tension and if so how do I put it back under the same tension? I have a book on the mag and a service manual for the trac but I can't find what I need to know. Thanks Ivan
