Creeper gears for G
JDGMC
03-15-2006 15:39:50
I've done a search and read everything I could but didn't seem to get an answer to my question. I've got a friend that has a fairly good pulling '46 G with 14.9-38s but when he hits a power track, he could use a lower gear like the 720/730 creeeper gear. He also happens to have another parts 720 w/creeper. Does anyone know if its possible to put the 720 creeper gear in the G. If possible, what would it take to pull this off? I'd sure appreciate an answer if anyone can give me one. I've been reading this site for over five years and know some of you guys know these two bangers pretty good. Thanks for any help you can provide.
JDGMC
The Dukester
03-17-2006 11:16:40
 Re: Creeper gears for G in reply to JDGMC, 03-15-2006 15:39:50
Cheapest thing to do here is get another set of rims, 12" wide will be fine for 13.6-38's or 14 inch for 15.5's(if the rules permit) and use these smaller diameter tires. If the track bites good, the 13.6's will be enough and be cheapest too. 13.6's and 15.5's are about the same diameter, but 15'5's have almost as much gripping surface as the 14.9's which, as you say are a little too much for power tracks. I'd leave the gears alone, I don't think it's practical to try to get slow speed gears into a G. JMHO
R W Wisehart
03-15-2006 18:40:52
You need ground speed to keep the sled moving, a creeper gear will not get it done.Sounds like you are running out of power.
JDGMC
03-15-2006 19:56:18
 Re: Creeper gears for G in reply to R W Wisehart, 03-15-2006 18:40:52
He only needs the creeper gear for two tracks - otherwise he's got plenty of power. The 720's that he pulls against beat him with a creeper. You're right though - he does run out of power on those two tracks. He's already convinced that in some cases it'll be an advantage.
We're going to compare parts books to check into the feasibility but didn't want to go without the wisdom of those on this board. They've helped me a lot in the past.
Thanks
Drew
03-15-2006 20:08:25
 Re: Creeper gears for G in reply to JDGMC, 03-15-2006 19:56:18
I agree with R W, ground speed is your friend. Worry about getting a little more thump in the thing instead of going slower.
