830 Transmission
hahter
03-15-2006 15:38:26
I heard that John Deere made an optional transmission for the 830. If so how do you know if a 830 has a standard or optional transmission.
Thanks for the help.
mike in shendoah valley
03-22-2006 18:32:27
 Re: 830 Transmission in reply to hahter, 03-15-2006 15:38:26
i have an 830 w/ creeper low. the best way to determine if its a creeper or not is to go from idle to full throttle and the tractor doesn't seem to change speeds.i later installed the std low gear and it became apparent that things had changed alot
AJB830
03-16-2006 14:21:39
hahter,
I have a JD 830 with the optional 1.5 MPH creeper gear. If the tractor has the original tachameter, the label for the 1st gear should show 1.5 MPH at 1200 RPM. I think mine does. If I look in my origianl operators manual, it shows a face plate marked 2.5 MPH at 1200 RPM. So this may be one way to tell without driving the tractor.
WeirdDeere
03-16-2006 02:58:49
As others said, there are no transmission options besides a "creeper" first gear. There is no way to tell externally which gear it has unless you drive it (I don't know if I could tell the difference between 1 1/2 and 2 1/2 MPH could you?), or count teeth on the gears.
Brandon
Glen in TX
03-15-2006 18:06:32
Slow first speed creeper gear. Check out options at twocylinderdiesel.com
hahter
03-15-2006 18:25:27
 Re: 830 Transmission in reply to Glen in TX, 03-15-2006 18:06:32
Glen,
Can you tell if a tractor has this optional creeper gear in transmission from the outside like in the shift gradulant.
Thanks
Glen in TX
03-15-2006 20:16:20
 Re: 830 Transmission in reply to hahter, 03-15-2006 18:25:27
Unless a parts catalog shows some kind of different outside optional parts I think the only way you will know is like someone mentioned by comparing ground speeds or opening it up to see and count teeth. I don't have a parts book and been too long since I've been on a 830.
hahter
03-15-2006 17:27:39
Yes I talking about a 2-cyl 830. I know that there was a optional transmission on the 720/730. I was wanting to know if there was an optional transmission on the 830 like the 720/730.
Thanks
hahter
03-15-2006 17:27:23
Thanks
Mike M
03-15-2006 16:42:36
If it's the two cyl. model then I think they offered optional gears you swap out under the cover on the LH side maybe low ? makeing it slower. You could check your ground speed. I think they used those around here (Ohio)back when these tractors were ran at tractor pulls in an unlimited weight class where platforms were made above and below and filled up with all kinds of steel and oil field drill bits.
I think my cousin got a set with his 820.
mjbrown
03-15-2006 16:30:36
On the 720/730, standard trans. had a 123-456 shift pattern. The optional so called low speed trans. the pattern is 124-356. The difference is accomplished with a different gear on one of the transmission shafts. I assume the 830 would be the same.
RalphinWI
03-15-2006 19:35:06
 Re: 830 Transmission in reply to mjbrown, 03-15-2006 16:30:36
I am of the opinion(!) that the R,through 830 had a different design than the B through 730. For the B - 730 it is a three speed transmission with a high/low range whether there are one or two shift levers sticking out of the case. In the case of my 820, I suspect it would qualify as a 6 spped rather than 3 x 2. I lost all interest in looking inside the transmission, especially after I lifted the brakes back in position. Fortunately I bought an 820 with a quiet transmission. My wife tells me I don't have time until next Wed to compare parts books for the A, 60 and 820
barnrat
03-15-2006 16:28:37
Do you mean 2cyl or 3cyl 830? If it's the 2cyl your talking about then I've never heard of an optional transmission. Unless you mean the fact that the 830 transmission is completely different than the other 2cyl transmissions out there.
