4320 Turbo
Jason Z in MO
03-15-2006 07:00:51
A neighbor has a 4320 and oil is running out of the turbo.
I have never repaired or rebuilt one but they don"t look too difficult. Anything I should be aware of before I volunteer? I don"t have a manual that covers this tractor but I will find what I need before tackling it. If it was mine I wouldn"t hesitate.
Suggestions?
Mike w J
03-15-2006 12:07:32
 Re: 4320 Turbo in reply to Jason Z in MO, 03-15-2006 07:00:51
Our 4440 had a seal go out and it let oil into the intake and they have about 35# of boost pressure so it leaked down the side of the engine out the intake gasket it was leaking past the turbo seal and started using oil real quick with lots of smoke but we did notice it soon enough that we only had to put intake gaskets in and a reman. turbo
Bob
03-15-2006 07:43:57
"oil is running out of the turbo"
Do you mean externally, or is it blowing oil out the exhaust or into the intake?
If the leak is EXTERNAL, take a good look at the turbo's oil feed and return lines, before condemning the turbo.
Jason Z in MO
03-15-2006 08:16:45
 Re: 4320 Turbo in reply to Bob, 03-15-2006 07:43:57
Bob,
Good suggestion, the oil is running down the engine block. I will take a closer look at the lines as you suggest.
However, I have known this tractor for a few years now. It has always, ALWAYS puffed blue smoke. If raw oil was leaking into the exhaust would it get hot enough to burn blue or would most of it come out raw on the hood?
I actually haven't looked to closely at this yet. He called me about the problem.
Bob
03-15-2006 08:28:33
 Re: 4320 Turbo in reply to Jason Z in MO, 03-15-2006 08:16:45
I would think a turbo oil leak into the exhaust side would spatter oil on the hood, especially when the engine is not warmed up.
Take a close look up under the hood, at the turbo, and see where the oil is coming from.
