494 Planter ?'s
Chuck McDonald
03-13-2006 19:34:13
Howdy,
I recently purchased a 494A planter from a friend of mine. This planter seems to be complete (or complete money pit if you ask my wife! blink.gif ).
My main question stems from looking over my Precision model of the 494A and old Deere Film footage.
I don't have the disks on either side of the seed shoe (might be called opener disks on modern planters.). Were these optional? How well will it work in plowed ground without them?
If I need them, Does ayone have 8 good ones they are willing to sell?
Thanks
Chuck "Diesel"
TIMAR
03-14-2006 11:23:54
 Re: 494 Planter ?'s in reply to Chuck McDonald, 03-13-2006 19:34:13
If you need parts parts, drop me an email and I will give you may cousins phone number. He has several he has salvaged or rebuilt
msb
03-14-2006 08:37:36
The idea behind the furrow openers was to throw some dirt away from the row and throw it back around the plant with the first cultivation,covering any small weeds in the row.Trouble was if the field got a heavy rain, the water would often pond in the furrow and turn the row into hardpan or could cause some erosion that would exposed the seed or even wash the sedd out of the soil.Furrow openers probably were the cause of more farmers buying rotary hoes than anything I can think of.The best use for furrow openers was to set them just low enough,to just skim the soil so they would knock any clods away from the row.
R.J.
03-13-2006 21:49:53
I wore out a 494A planter that had those furrow openers mounted to each side of the seed shoe. They were to use when the ground was getting dry on top, then you made a small furrow to put seed in moist ground. And then hoped you didn`t get a heavy rain at least until the crop was up.
504
03-13-2006 19:56:52
The were for fertilizer,the seed drops thru the shoe.
Mike Aylward
03-13-2006 19:55:12
Chuck, the double disk openers were indeed an option on these planters. In my area they are seldom seen. The runners on your planter were designed for "clean" ground and will work best in plowed ground. If your planter has a round pipe front frame instead of square you have a 494. If it is square it is the "A" series. Hope this helps. Mike
