need help 730 gas
piston
03-13-2006 18:49:18
have bad fuel pump, anyone know where to get one ??, can you use electric pump, or do you have to have one at all?, looks like gravity flow would work tank is higher than carb thanks help if get any.
Keith JD620
03-14-2006 04:22:25
 Re: need help 730 gas in reply to piston, 03-13-2006 18:49:18
piston- The thing that you took apart is an automatic fuel shut off. The small lines that attach to the "T" are oil pressure lines. I assume that your tractor wasn"t getting fuel since you were tearing into it. The diaphragms that you found hold motor oil and when the oil pressure expands them it opens the valve at the bottom of the valve body and allows fuel to gravity feed from the tank to the carburator. If you have it apart clean it thoroughly and replace the little rubber seal on the valve as well. If the diaphragms were bad it you likely have gas in the engine oil. I would change the oil and filter as well.
piston
03-14-2006 04:11:10
thanks youall help its makes all comes together now , i see the oil line going to motor an to guage, the last j.d. i owned wasin 1968, i have forgot a lot about j. d. but thats the good thing about formum, ask an you will receive, usually///
B. Abseck
03-13-2006 23:34:01
Piston, I can't help with your problem but I want to get a 730 and would like to know what you think of yours. What you use it for, how long you've had it etc...
piston
03-13-2006 19:30:46
well i would call it a fuel pump its right b/4 the carb gas line goes to it an vacum line goes to it , i took it apart an it has 2 diafraims in it , looks like pump to me , cant tell if its been added or not, looks rginal to me
960
03-13-2006 20:36:33
 Re: need help 730 gas in reply to piston, 03-13-2006 19:30:46
That is an automatic fuel shutoff and you get parts from Deere. As the post said it is gravity flow no fuel pump.
Bob
03-13-2006 22:02:48
 Re: need help 730 gas in reply to 960, 03-13-2006 20:36:33
And, tell him it is not a "vacuum line" to the shutoff unit, it is an engine oil pressure line!
Mike M
03-13-2006 19:01:40
A 730 gas IS gravity flow ?? If you have a fuel pump someone must of added it.
