G crank in an A
potentpuller
03-13-2006 12:40:02
Would it be possible to put a G crankshaft in an unstyled A?
The Potent Puller
Drew
03-13-2006 16:15:39
 Re: G crank in an A in reply to potentpuller, 03-13-2006 12:40:02
I have heard RUMORS of this being done before with some machine work....Why do you want to do that though? You are not going to feel a seat of the pants power increase. You can put a styled crank in that is 6.75", and it would bolt right in. That would be a little better than what you have now. A good cold manifold, port match and valve job along with high compression pistons would get you as much more power with less work.
IFFFFF it is infact possible, its going to be a lot of time and $ for little return.
