Power for the clutch comes forward along the steering/hydraulic lines under the hood (yellow wire). It drops down in front of the coolers. Some have a high temp cutout in this wire, clamped the the AC condensor outlet, at the lower front LH side of the AC condensor. The wire follows the high-side and liquid lines back to the compressor. With the AC thermostat calling for AC operation, there should be battery voltage at the thermal fuse, where the yellow wire connects. The other terminal connected to the AC clutch should also have battery voltage. The third terminal on the thermal fuse goes to the "superheat switch" in the rear head of the compressor. At times of high suction gas temperature, due to a low refrigerant charge, or aggravated by clogged condensor airflow, the "superheat switch" closes, and activates a heater in the thermal limiter fuse that will melt a fusible link, and disconnect the AC clutch from power within a minute or two. (This is a time-delay, to avoid blowing the thermal protection fuse unecessarily.) So, temporarily jumpering the 2 terminals on the thermal limiter fuse NOT connected to the switch in the compressor's rear head will eliminate the thermal fuse, and the compressor should start, if the problem is the fuse.
