9 bolt wheels and tires
jd plowboy
03-13-2006 07:06:58
looking for set of 15.5x38 tires on 14x38 9 bolt wheels. no luck on ads
Junkman
03-13-2006 09:44:36
 Re: 9 bolt wheels and tires in reply to jd plowboy, 03-13-2006 07:06:58
I am looking for a set of 15.5x38"s on 14x38 rims for G cast centers in central MO?
Mike Aylward
03-13-2006 09:33:10
JD Plowboy, I can probably help you out. Where are you located? Mike
jd ployboy
03-13-2006 11:16:20
 Re: 9 bolt wheels and tires in reply to Mike Aylward, 03-13-2006 09:33:10
i am in south carolina 45 miles south of columbia
amo
03-13-2006 08:40:32
I WAS LOOKING FOR A RIM FOR MY OLD B MODEL AND FINALLY FOUND A RIM OFF OF AN OLIVER THAT WOULD WORK, IT WAS THE 9 BOLT RIM I HAD, GOOD LUCK.
Duane Larson
03-13-2006 15:58:27
 Re: 9 bolt wheels and tires in reply to amo, 03-13-2006 08:40:32
amo,
You are correct that an Oliver rim will bolt up, but if you look carefully an Oliver wheel touches the rim in five places, while the wheel used on a JD touches the rim in four places. So, they look different.
FWIW.
