36 A clutch whine/growl
MDM
03-12-2006 19:48:34
I have a 36 A with a distinct whine/growl that seems to be coming from the clutch/gear reduction cover, it only does it when in gear and moving at an idle, when motor is running at approx 1/4 throttle or above...it goes away....when in nuetral and clutch engaged, it is quiet. any ideas of where to start?????
Jason Mills
03-13-2006 05:40:21
 Re: 36 A clutch whine/growl in reply to MDM, 03-12-2006 19:48:34
Dad's A had this problem last year. It was a bearing on the input shaft to the transmission. When we tore it apart, what was left of the bearing was in the bottom of the case. Good Luck, Jason.
MDM
03-13-2006 08:26:53
 Re: 36 A clutch whine/growl in reply to Jason Mills, 03-13-2006 05:40:21
thanks
