Diesel Tank Repair on JD2440
Carl Ernst
03-12-2006 18:08:54
I have developed a leak on the lower front side of the fuel tank of my JD 2440 D. I removed the tank and can see 2" x 3" rusted area where the leak has developed. A new tank from JD costs $670 and I will contack local radiator shops for estimates on repair of the existing tank. The rusted area appears to be where the tank has come in contact with front frame. I also noticed a thin fabric liner that was to provide shock absorption between the frame and the tank. This liner is deteriorated however JD does not list a replacement for this liner. Does anyone out there have experience with repairing diesel tanks and any suggestions on materials I could use to cushion the tank from the frame?
Mike M
03-13-2006 19:06:54
 Re: Diesel Tank Repair on JD2440 in reply to Carl Ernst, 03-12-2006 18:08:54
I'd clean that area of the tank really good and also flush the insides out good with a hot water pressure washer and soap then use acid core solder and fix it up real good. JB weld will tend to crack and leak.
matthies
03-12-2006 19:36:15
Clean it off good and jb weld it. I have a gas tank on my pickup that hasn't leaked in 5 years with jb. Ask your Deere dealer for the fabric stripping that comes in a radiator foam kit for jd tractors, really good stuff I use it for everything. And don't let him tell you it's not available separately, thats BS. chris
