Clutch Brake Assembly JD B
gene37
03-12-2006 14:46:57
Trying to remove the Clutch and Brake assembly according to the maintance manual and it will only come out from the reduction gear housing about 1 inch and not come off. Any ideas?
Thanks in advance.
Gene
Mike M
03-13-2006 07:31:28
 Re: Clutch Brake Assembly JD B in reply to gene37, 03-12-2006 14:46:57
Was your clutch in the released position before starting to remove ?
gene37
03-13-2006 10:36:21
 Re: Clutch Brake Assembly JD B in reply to Mike M, 03-13-2006 07:31:28
By release I assume you mean clutch disengage. I have tried it both ways with the same results. I only get about 1/4 to 1/2 inch movement on the shift lever. Is this normal amount?
Mike M
03-13-2006 12:00:16
 Re: Clutch Brake Assembly JD B in reply to gene37, 03-13-2006 10:36:21
If you are working it down at the fork lever it won't move very much. Do you have the adjusting nuts loosened so it can snap disengaged easy ? Or even take out all the facings and clutch plates. Once in awhile you need to do some wiggling to get them loose.
Pappy
03-12-2006 23:48:26
If you are removing the clutch and pulley, remove the four bolts that hold the pulley brake mechanism on the front of the clutch housing mechanism in front of the pulley. Pull this mechanism forward and lay it aside. Your pulley should slide out and come free. When putting it back, be sure your clutch release is installed into the grove in the drive sleeve.
Gene37
03-13-2006 05:06:25
 Re: Clutch Brake Assembly JD B in reply to Pappy, 03-12-2006 23:48:26
I did remove the 4 bolts from the clutch and brake housing but when I pull it forward about an inch it gets hung up on something. I think it must be something in the shift fork area.
Gene
Bguy
03-13-2006 10:50:54
 Re: Clutch Brake Assembly JD B in reply to Gene37, 03-13-2006 05:06:25
Gene37, Like pappy said, take the clutch housing mechanism off first. You usually have to move it up and down, sort of work it out of there. The fork inside goes into a groove and it has to be wiggled out. Make sure the part with the bronze facing goes back into the groove when you put it back together. Seems kind of awkward the first time or two.
boll weevil
03-12-2006 15:14:41
take the 4 bolts out of the clutch break(on the back) pull that towards the axle then the reduction gear will come right out!
Good luck
