Could be big trouble?
Kurt_JDB
03-12-2006 13:18:04
Been hearing a racket from the neighborhood of the clutch/reduction gear cover every time I engage the clutch (tractor in gear) of my "51 B. I removed the clutch today, and I could see where the end of the crankshaft bearing cap was scored. I measured the endplay on the crank, and it was about .020. So I thought maybe this was the proble. Then I reached into the first reduction gear cover and grabbed ahold of the first reduction gear. I could move it around quite a bit. It seemed to move in and out at least a quarter of an inch, or maybe it was wobbling. Turns real smoth with the transmission in neutral.
Two questions:
Should the first reduction gear move around like this?
What is allowable end play on crank, and how to adjust?
Thanks,
Kurt
Pappy
03-12-2006 23:28:16
 Re: Could be big trouble? in reply to Kurt_JDB, 03-12-2006 13:18:04
Endplay should be from .005 to .010. Loosen the flywheel, push it in closer to the engine. Tighten the bolts real good. You will have to hold the crankshaft from the clutch side to keep it from moving. If your first reduction gear is moving, your bearing on the end of the shaft is probaably shot. This is the small bearing in the center of the reduction gear cover. This would be my first thing to check.
Kurt_JDB
03-13-2006 04:23:34
 Re: Could be big trouble? in reply to Pappy, 03-12-2006 23:28:16
Thanks, Pappy
I will check out this bearing in the cover. I noticed there seems to be a small cover over the location of the end of the shaft in the cover. I will start there.
Kurt
