"Oil pressure will seem to be okay for a few seconds then pegs the needle." Oil pressure senders often go bad and cause this, or you may have ground problems in the gauge panel. Identifying the ground on the oil gauge (and the voltmeter) and connecting them to a good ground will fix that problem. "Alternator gauge seems to be all over the place, both over charging and under charging. New alternator on tractor, tested out of the box before installed." Check the 2-wire harness and connector at the alternator for broken wires and dirty terminals. Also, as previously mentioned, a bad instrument panel ground can cause the gauges to go mickey. Identifying the ground on the voltmeter (and the oil gauge), and connecting them to a good ground will fix that problem. "Temp gauge does not move. Connection on sending unit looks good."
Remove the wire from the temp sender, and connect it to a good ground with a jumper wire. The gauge should peg "HOT". If the gauge still does not move, check for power and ground at the temp gauge.
