2030 Diesel injectors???
Ponchobro
03-12-2006 09:04:13
Hello, My 2030 starting smoking alot when cold. I was told the injectors may need to be cleaned. Is there a good way to do this or will they need to be replaced. Thanks
jdemaris
03-12-2006 20:29:10
 Re: 2030 Diesel injectors??? in reply to Ponchobro, 03-12-2006 09:04:13
We pulled apart a lot of Deere engines with cold starting, smoking, or skipping issues - especially with the 30 and 40 series. With a high-hour engine, the injectors just about always check out bad. But, that being said, I've yet to see a cold-smoking tractor get fixed with an injector change. I would be more suspect of the fuel-timing advance not working properly which is very common with the Roosamaster JDB or DB pump. Easy to check with an timing-window and can be adusted with the pump on the tractor, engine running. Often, a static advance of 1 or 2 degrees helps also. We had to do it with some new tractors, especially 2940s. General overall engine wear will do it too - and often such wear will not show up in a compression test. Valve depth is critical on those engines, and with wear (or with a bad valve job) the valve recess gets pretty deep and will cause the engine to skip an smoke when cold. It only takes .010" - .020" excess depth to do it. This will not show with a compression test. In regard to the pencil-injectors, they are throw-away items. No main service parts have ever been available for them, i.e., when you see them advertised as "rebuilt", it's nonsense. They're cleaned and pressure-set. The main parts can't get replaced, but are sometimes reground. Regardless, they won't have the service life of a new injector. On getting them out, be careful. As the other guy metioned, they should be coated with Never-Seiz when installed, but often they're not. I've had several that I had to pull the head off, and press them out from the inside because they were hopelessly stuck. That's enough to ruin your day when you're on a service call and have to do that in the middle of a woods on a zero degree day. There is a special pulled made for them, but for the most part, it's useless on a badly stuck injector.
G/MAN
03-13-2006 10:35:01
 Re: 2030 Diesel injectors??? in reply to jdemaris, 03-12-2006 20:29:10
Had one in a Caterpillar 3306 in a 973 track loader once that wouldn't come out even with an overhead chain hoist hooked to it. Had to pull the head and beat it out. Makes a "cheap" job real expensive in a hurry...
G/MAN
03-12-2006 13:38:17
Having the injectors "cleaned" is a pretty generalized and misleading term. There are actually three items that need to be checked when dealing with fuel nozzles. First, the opening pressure needs to be up to specs. The nozzle is nothing but a spring-loaded relief valve. When the pump supplies flow to whichever injection line, pressure builds in the line until it's high enough to overcome the spring pressure in the nozzle, at which point the needle moves off its seat and fuel in injected through the tip into the cylinder. If the spring is weak or broken (and they ALL get weak and the opening pressure drops over time), the pressure required to unseat the needle gets lower, resulting in poorer fuel atomization, a colder "fire" and possibly unburned fuel, which will come out of the engine as smoke - usually gray/blue smoke. The next item is the spray pattern. The tiny holes in the nozzle tips are drilled in a specific pattern to match the piston and combustion chamber designs. If some holes are plugged or distorted, it screws up the pattern and the fuel burn again. Last is tip leakage. If there is leakage between the needle and its seat, fuel may drip out of the tip constantly instead of only being injected at high pressure at the proper time. This is a big problem, as it can lead to "blowtorching" a hole in a piston if it gets bad enough. If you're convinced it's a fuel system problem, you need to remove the nozzles and have them tested - all three tests can be done at once. If they're bad, and they likely will be, the most economical fix is probably replacement with new. I believe your tractor uses the good old Stanadyne pencil-nozzles, and they're usually only about $75 or so per unit. They COULD be "cleaned" and rebuilt, but it's really not very cost-effective when you can stick brand-new ones in for not much more. The new ones will also come with the washers and carbon seals installed, which will save you that hassle. You'll want to clean the nozzle bores well with a bore brush. I usually put a drop or two of oil on the carbon seal, and coat the rest of the nozzle body from the seal up with anti-sieze so they'll come out easily next time. While the nozzles are out, it would also be a good idea to check compression, to verify that it's up to snuff, as if it's low, new nozzles may not clear your hazing problem.
