JD 4240 Electrical Problem
Darrell Sears
03-11-2006 17:59:11
I have replaced the 6 volt batteries, but I made connection with the + terminal to the frame while removeing the old battery. There were come sparks. Now I don't seem to have power to anything. Any suggestions???
Bob
03-12-2006 09:16:01
 Re: JD 4240 Electrical Problem in reply to Darrell Sears, 03-11-2006 17:59:11
Turn the lights on, so there is a load on the batteries.
Start at the RH battery. With a test light, or meter grounded to the chassis, the (+) post on the RH battery should have about 6.25 Volts (or light the test light to 1/2 brightness).
Then, touch the meter to the RH (+) battery cable end, to verify it is making contact.
If there's juice that far, cross over to the LH battery. The cable terminal on the (-) post of the LH battery should have the same voltage, as well as the (-) battery post, indicating that the crossover cable from the RH battery is OK, and making contact.
Then, check for 12.5 Volts on the (+) terminal and attached cable end. If there is good voltage that far, move up to the starter.
First off, verify that the transmission is in "PARK", so you don't accidently get run over, if the starter kicks in because you accidently short to the "S" terminal on the solenoid.
You need to check for voltage at the large battery cable post on the starter solenoid. This may be (and SHOULD BE) covered by a safety cover to prevent jump starter and running over yourself.
Having made SURE the tranny is in "PARK", check for voltage at the large upper solenoid terminal, removing the safety cover, if present.
If there is 12.5 Volts to that stud, the batteries and cables are OK. There will be a good-sized wire on the solenoid stud, along with the battery cable. That wire feeds power to the rest of the tractor. Make sure the connections at the solenoid's battery stud are all clean, and the nut is tight, and there is actually power to the large wire leaving that post.
REPLACE THE SAFETY COVER WHEN DONE, OR GET ONE FROM DEERE, IF IT IS MISSING (should be FREE).
If you have power that far, and the tractor electricals are still "dead", post back.
(From the solenoid stud, IIRC, the large wire runs up to the front of the firewall. There may be a large quick-disconnect there, between the engine harness and the tractor harness. Also, on the RH front of the firewall, there is a start solenoid that activates the main starter solenoid for starting. One terminal of that solenoid should have battery power at all times. From that solenoid/quick disconnect area, the power goes to the circuit breaker panel under the LH steerinbg pedestal cover in the cab. There are 2 buss bars there... the front buss bar should have battery voltage at all times, the rear buss bar is fed through the master relay that comes on with the key switch.)
Post back with what you find, and BE CAREFULL working with the starting system.
Tx Jim
03-12-2006 04:15:43
Darrell,when you say no power to anything does that mean no head lights working,no gauges working? Might be a relay. Circuit breakers and relays are underneath cover that is in front of dash on LH side. Tx Jim
