2520 oil pressure light
Machinery-man
03-11-2006 14:03:05
Does anyone know the minimum pressure to put out the light from the sending unit. Also the normal oil pressure for the tractor. Thanks Chuck
Glen in TX
03-11-2006 17:48:14
 Re: 2520 oil pressure light in reply to Machinery-man, 03-11-2006 14:03:05
It shouldn't take much or any to throttle up right after starting the light should go out. Check a TM1004 2520 manual to be sure. 2520 has 219 and 2510 the 202 diesel. All the I&T JD-33 for 2510 & 2520 says is 30-40 psi for early models and 50-60 psi for later models with engine at operating temperature and 2500 RPM. Later 2510s had a oil pump update same as 2520. JD SM2070 for 2500 series says the same thing on pressure. Check this pressure by removing the sender switch and connecting with a known good oil guage. If oil lamp fails to light check for good bulb and with key switch on, pull the elec. connector off the sender and ground the connector to the tractor and if it lights then the sender is bad. If oil lamp stays on after engine is started and has known good oil pressure pull the elec. connector from sender and if lamp goes out the sender switch is bad. If it doesn't go out check wiring and lamp. Oil pressure can be adjusted by removing the RH front cover plug by filter area for relief valve and add shim washers between spring and plug to increase pressure or remove shims to lower.
Glen in TX
03-11-2006 17:54:07
 Re: 2520 oil pressure light in reply to Glen in TX, 03-11-2006 17:48:14
Also very important: You should not require more than 4 shim washers to increase oil pressure to recommended psi. If more than 4 are needed look for other problems causing low oil pressure.
