1944 JD -A
Mike at treasu
03-11-2006 13:19:30
Just bought a 1944 JD-A that was froze up.Got it loose and there is a little pitting on cylinder walls.There is no ridge on top of cylinder so I suspect it has been rebuilt some time.Would a guy be smart to ring it or just clean it up and get it going?Any advice would be much appreciated.
greenmech
03-11-2006 16:25:31
 Re: 1944 JD -A in reply to Mike at treasure, 03-11-2006 13:19:30
My 44A was stuck and had some pits in it. I honed the cylinder and installed new rings. If your rings are in good shape, they may work ok. Good luck. Ron Mn.
ol' guy
03-11-2006 15:10:24
I went through the same experience with a '45 "A" 2 years ago. I just cleaned everything up, freed up the valves, etc. re-did the carb and mag. and the more I ran it the better it performed. The crankcase was clean, and the oil was even clean when I first opened it up, indicating it had had "reasonable" care. Good luck with whatever you decide to do.
