'37 A Governor parts and block question
Rekabnivek
03-11-2006 12:39:03
Where can I get the weights, thrust bearing, and fan gear set for the governor of a 1937 JD A?
Also the block in my tractor has a tag on the top that looks the be screwed on that reads 191-37. What does this tag mean?
Thanks
Kevin
greenmech
03-11-2006 16:17:44
 Re: '37 A Governor parts and block question in reply to Rekabnivek, 03-11-2006 12:39:03
Those weights are spendy,I would have them rebuilt at a machine shop unless you can do it your self. Thrust bearing ,get at Deere. Ron Mn.
Papas38
03-11-2006 13:16:45
You can still get these parts from deere but be prepared to write a big check. NOS fan gear sets can sometimes be found on ebay and at swap meets, but it important you get a matched gear set.
