Head gasket?
RedJD
03-11-2006 11:45:50
Started to put the head back on my A that I'm rebuilding. I have had the gasket set for several years and I noticed the head gasket has come apart in some places.One side is metal and the other composit material.Around the edge of the gasket the metal is separated from the composit.Should I get a new one or is this safe to use.
Mike M
03-13-2006 12:12:31
 Re: Head gasket? in reply to RedJD, 03-11-2006 11:45:50
If it is the real old type that the center composite is white and not gray than if it isn't cracked it may be better than the new ones as it is asbestos. On those old ones you soak them in oil per the book or I have used water. You can hear them sucking it up,this softens them when you tighten them down they seat in better. The new gray ones are some kinda hard fiber and I don't much care for them.
G/MAN
03-12-2006 13:55:21
I tend to agree with F-I-T. Not all of those gaskets are going to be 100% bonded. Some gaskets are made differently than others, and if the seal is dependent on the parts of the gasket being bonded together when the gasket isn't installed, instead of when it's installed and under hundreds and thousands of pounds of clamping load, there would be something wrong with that. Most gasket-sealing issues are related to warped surfaces and improper installation/assembly, not a failure of the gasket itself. But, if you want peace of mind, get a new one and send me that old one, lol.
Glen in TX
03-11-2006 16:21:58
I've had several head gaskets for Ds that were like that and not bonded on the edges but they worked fine. If the composite material inside is old and cracked or pieces of it missing then worry about getting another one.
F-I-T
03-11-2006 15:15:25
They're not really bonded. Many new ones that I have used have proper crimped material edges, but where it is just laid on top with no crimp, it is not glued and it might be lifted up a bit. Those areas are pointed away from the pressure areas and fire rings. I believe it is just meant to press together and the torqued head to block pressure will do just that.
Just my humble opinion.
Frank
gmc ronnie
03-11-2006 11:47:29
i would get a new one ,
TomWindsor
03-11-2006 18:35:04
 Re: Head gasket? in reply to gmc ronnie , 03-11-2006 11:47:29
It sure is a lot of work to run the risk of it leaking...my vote is get a new one.
