!937 JD B
Mike in Wi.
03-10-2006 17:37:10
Hey guys -I can still not get my 1937 B to idle down.Carb is rebuilt,no vaccum leaks,new plugs.It wants to back fire once in awhile while trying to idle down.It wants to surge up and down while trying to idle. Also can get it to idle better if choke is half on.Any ideas?Thanks
sgtbull
03-11-2006 06:51:33
 Re: !937 JD B in reply to Mike in Wi., 03-10-2006 17:37:10
My first thought is the idle passage. It is most commonly blocked at the point where it runs horizontally, at its lowest point. (go figure.. that gravity thing you know) On the lower part of the carb stem, there are two brass plugs. One is kinda offset on the stem and is on a bit of a "swell" on the side of the stem. Remove this plug, and remove the idle needle. (note: heat the plugs first w/ a torch.. they will come out easily, otherwise you'll screw up the screwdriver slot by trying to force them out)Find the smallest penlight you can, shine it down the idle needle hole, and look inside the hole you removed the plug from. Its likely you can't see the light. The hole is a stepped down hole. Its large, then gets tiny right before it joins the idle needle passage. That is where it is most often blocked. It is usually rust, and solvent won't help. You need a numbered drill bit, and you can carefully clean the passage out. I've used small acetylene torch tip cleaners, but you have to be carefull and not break it off..then you have REAL problems. That should fix your idle problem, if it was blocked. If not, you might start looking at your linkage adjustments and freedom of movement in the linkage. Finallly, you may have to crack open the governor..not fun, but not difficult either...but hold on to your wallet. You can drop $300 plus without even trying inside that thing. Just a note to anyone else reading this: If you redo carb's very often, a small fiberoptic attachment for a minimag or brinkman flashight will fit INSIDE most passages, and make inspecting them a breeze. they cost about $10 and are usefull for lots of things. I got mine in the tool section at Lowe's. The only other hint is to turn off the lights in the shop and use the light... you can see partial obstructions that you couldn't identify by "spraying and looking for it to come out".
Glen in TX
03-10-2006 20:22:08
Mike, You probably need to give the carb a good cleaning and soaking and run wire and number drills through all the passageways after removing the brass plugs. Also need to remove the nozzle in center under bowl nut and clean out there. A kit will have basic parts you need but check other parts like throttle and choke shaft, bushings, & butterflys for wear also. Check your float to make sure it doesn't have fuel inside it also by shaking it. The float can be checked for leaks by holding it with pliers in hot water (not boiling) and you will see air bubbles spewing out if it leaks. It can be repaired by soldering if you are good at that. You can also check float level with carb on tractor with clear tubing in drain fitting and it should be about 3/4" from bowl top edge. Also might want to disconnect air cleaner intake and run it like that and see if any change indicating a intake blockage of grease crud or mud dauber nests. More carb info at these links: jdhpubs.com and Roberts.
bear4work
03-10-2006 18:37:40
If it idles better with the choke half on, that means you might need to clean the carb out or you need new gaskets. Take the carb off, squirt it generously with carb cleaner, you might need to take it apart or let it soak overnight in carb cleaner. Then make sure you put it back together correctly and see how that works. I did this with a "43 JD A which ran only with fully using the choke all the time, I did this and with minor adjustments it ran perfect and could idle to the point where you could count the fan blades as they went around. Good luck and hope you fix your Carb.
