730 Dsl Engine Oil Power Steering Questions
Charles Beavers
03-10-2006 16:51:45
First Question: Is it OK to use synthetic oil in JD 730 Dsl Eng and is 15 - 40 weight the best??
Second Question: When I turn the steering wheel on the 730D to left sometimes it turns hard (turning right always seems OK)..What is the most likely cause??
Thanks very much...Charles
F-I-T
03-12-2006 15:02:34
 Re: 730 Dsl Engine Oil Power Steering Questions in reply to Charles Beaverson, 03-10-2006 16:51:45
third party image
Charles:
"Second Question: When I turn the steering wheel on the 730D to left sometimes it turns hard (turning right always seems OK)..What is the most likely cause??"
It could be low oil flow, so that if you adjust the flow valve a bit (first picture) it might steer better, but you have to be careful no to go too far or the front end may flutter.
If that does not cure it, I would suspect that you have a notch or distinct flat worn on the face of the actuator cam, and probably flats on the pin that slides between the cam faces. Flat spots will inhibit the smooth motion of the cam and pin, which is supposed to slip up or down the cam when turning resistance is encountered, and inturn push the poppit valve fore and aft which is how the hydraulic assist is called for.
If you undertake to rebuild the acutator and such, by a proper manual and ask questions because you can hurt yourself if the you don't set it up correctly.
Hope the pictures help.
Frank
Charles Beaverson
03-13-2006 11:35:45
 Re: 730 Dsl Engine Oil Power Steering Questions in reply to F-I-T, 03-12-2006 15:02:34
Frank,
Thanks alot for the information on the power steering. You been a great help.
Thanks...Charles
730 Mike
03-12-2006 07:14:32
Hi Charles, I use 15-40 in my 730D. I prefer shell rotella but have used other brands. If you want to use synthetic it should be ok as long as its for diesel engines and a heavy enough grade. As far as the steering I have the same problem once in a while but only when idiling. I have no leaks and fluid level is good. So if you find out what it is let me know. Sorry I can't be of more help.
Mike
