3020 Transmission Proublems
Billy Goldsmith
03-10-2006 08:46:51
I have a 3020 with the power shift trans and the proublem is that in the past 6 months I have replaced the two canister trans filters and fluid about 5 times but after a very short time of operation (like an hour or so) the tractor will not move and the proublem seems to be that there is a screen filter that is behind the two canister filters and it clogs up. When I take it out it looks to have small little metal fragments in it that are silver and gold in color along with a lot of other stuff I cant identify. Any ideas on what may be causing this and how do I fix?
msb
03-10-2006 08:49:23
 Re: 3020 Transmission Proublems in reply to Billy Goldsmith, 03-10-2006 08:46:51
Sounds like the brake pads have come apart.
Billy Goldsmith
03-10-2006 08:59:35
 Re: 3020 Transmission Proublems in reply to msb, 03-10-2006 08:49:23
Is it a big deal to fix? From a cost standpoint as well as is it hard to do?
G/MAN
03-10-2006 13:48:00
 Re: 3020 Transmission Proublems in reply to Billy Goldsmith, 03-10-2006 08:59:35
The final-drives have to come off, and there is a stationary backing plate with 3 pads mounted to it, a disk and three pistons with pads that fit in bores in the differential housing, and are pushed out to squeeze the disk between them and the pressure plate. If the disks aren't too far gone - they usually aren't unless the friction material is completely gone and you've had metal-on-metal - the brakes aren't terribly expensive to redo. You reuse the plates and pistons, and have new friction material riveted to them. The job is made much easier with a rear-wheel dolly, so you can leave the final-drive, axle and wheel assembly all in one chunk and roll it away from the tractor. A service manual will show you exactly what you're dealing with.
