40T Hydraulic oil leaking into the engine?
flagdeer
03-10-2006 07:30:16
Has anyone had a 40T with factory 3pt leak hydraulic oil into the engine?? I have noticed that my hydraulic reservoir has gotten lower while my engine oil level increases. Would a bad hydraulic pump seal cause this??
Thanks in advance.
Henry M
03-10-2006 11:50:39
 Re: 40T Hydraulic oil leaking into the engine? in reply to flagdeer, 03-10-2006 07:30:16
If your shaft has a groove in it and someone locally is familiar with using jiffy sleves, it can be fixed that way without replacing the shaft, depending on availability and price.
jd5440u
03-10-2006 10:22:35
I've had a "40U" with a #30 loader since 1965. I had the same problem many years ago. The hyd pump shaft had a groove worn in it, so replaced both shaft & seal. Many hrs(probably thousands)later it's still doing fine. As I remember, it wasn't a real cheap fix even then & is on doubt more now, providing Mother Deere still has the shaft available at all.
Thane
03-10-2006 09:04:30
Yes, I have a 40W, and the seal at the hydraulic pump allowed the oil to leak into the engine. Every time I used the tractor, the engine oil level rose. I took the pump out, replaced the gears in the pump, put everything back together. It solved the problem.
Hayfarmer
03-10-2006 07:39:32
The only place where the hydraulics and engine come in contact is at the pump drive. I suspect that the pump seal would have to be leaking to cause hydraulic oil to get in the engine.
Flagdeer
03-11-2006 13:47:48
 Re: 40T Hydraulic oil leaking into the engine? in reply to Hayfarmer, 03-10-2006 07:39:32
Thanks for the replies, it is nice to know I havn't gone completely crazy, yet. I will tear the pump off and see how the shaft and seal look. Thanks again for the help.
