Crude K, I pasted this from a earlier response. Yes, you need to polarize it. A generator quick check from Delco manuals: Cranking Complaint: 1. Check drive belt tension. 2. Be sure that battery is fully charged. 3. Inspect wiring, clean and tighten all connections. 4. If none of the about corrects the trouble proceed to following tests or remove generator for service and repairs. Undercharged Battery: 1. Check drive belt tension. 2. Inspect wiring, clean and tighten connections. 3. Connect voltmeter from motor-generator "A" terminal to ground. 4. Ground motor-generator "F" terminal. Leave all wiring leads connnected. 5. Operate engine. If no voltage is obtained, remove generator for further checks. 6. If voltage is obtained, check regulator and wiring further. Overcharged Battery: 1. Connect voltmeter from generator "A" terminal to ground. 2. Disconnect lead at generator "F" terminal. Leave other wiring leads connected. 3. Operate engine. If voltage is obtained, remove generator for further checks. 4. If no voltage is obtained, check field lead and regulator. Connect voltmeter at battery and should have 12-14V or 6-8V. Also be sure to polarize the generator each time battery or leads have been disconnected or changed. Delco is a "A" circuit type.
