Brush mower gear box
Mike S
03-10-2006 07:01:40
I have a 60hp gear box off an old cutter. It is marked W24241 JD and it has a slip clutch on it. Is there a site that has a parts breakdown of this gear box? How do I take the slip clutch apart to get it off?
Glen in TX
03-10-2006 10:27:55
 Re: Brush mower gear box in reply to Mike S, 03-10-2006 07:01:40
Mike, It comes up on JD Parts where used search as fitting a 506 and 606 rotary cutter. Most of those had a big nut on them that has to be loosened to get the clutches apart. JD supplied a wrench for that when shredder was new and it was short so a long cheater pipe could be put on it to loosen or tighten nut on clutch.
Mike S
03-10-2006 13:51:36
 Re: Brush mower gear box in reply to Glen in TX, 03-10-2006 10:27:55
Thanks, that was just the info I needed. Found out that it does not need gaskets, just some blue goop should stop the leaks. It is a heavy duty gearbox compared to the one from Ford or Bushhog.
Glen in TX
03-10-2006 20:48:38
 Re: Brush mower gear box in reply to Mike S, 03-10-2006 13:51:36
Go easy on the blue goop and don't get too much squeezed out inside the gear box. Permatex Right Stuff, or Indian head shellac, or Aviation sealer or High Tack works well there too. Of course it's heavy duty, it's a John Deere!!
