40 horsepower with only aluminum pistons?
Tye W
03-09-2006 19:11:45
I am still playing with the idea about a power block for my 50. Someone mentioned on this board that you can get about 40 horsepower with additional length aluminum pistons. Is this possible? If I can get about 40 hp without a power block then I 'll forget about the power block. Any other ideas for power? This tractor is strickly for work and some pulls on the side. Thanks for the help. --Tye
DickD
03-11-2006 01:44:03
 Re: 40 horsepower with only aluminum pistons? in reply to Tye W, 03-09-2006 19:11:45
Tye; Sounds like you intend to work your "B". If you alter your engine, a water pump is a MUST.
jd b puller
03-11-2006 17:43:03
 Re: 40 horsepower with only aluminum pistons? in reply to DickD, 03-11-2006 01:44:03
Dick, are you stating that as a fact or an opinion about the water pump? I ask becauase we've run B's, A's and 70's on the farm all with Powerblocks 10 hours a day (back in the day). No water pumps and no overheating. Can't remember, maybe the 70 came std with water pump. I know the A and B we never put one on.
DickD
03-12-2006 02:29:59
 Re: 40 horsepower with only aluminum pistons? in reply to jd b puller, 03-11-2006 17:43:03
JdB Puller; My father had a 39B he had installed inserts in the cylinders to up the compression. I couldn't see any extra power, but the engine would heat up when worked. Also I have a B that is bored .187, and .100 off the block, which I just use for pulling. It will heat up after an hour or so of working the engine. I have a 70 and it does have a water pump, So my input is from my own experience. Take care Puller, and thanks for asking.
Mike M
03-10-2006 11:14:05
40 HP ? I don't think so on regular gas ?
I do think that you can get close to 35 HP if you have some of the M&W add power pistons and reg. gas. I had a late B that had those and it made 35 or about ? My stock (propably .045 over) kinda worn 50 did 31hp.
ET
03-10-2006 05:08:47
I have a 50 also and was playing with the same idea as you. I even had the power block but no pistons. I decided to go with high compression aluminum pistons over the power block. The pistons for the power block cost $400, and the sleeve material in those blocks seems to wear a little faster than the cast iron block. For a working tractor I don't see the advantage and the cost is a lot more to go with the power block. I sold my power block at the NY expo last summer and the proceeds will pay for aluminum pistons and to send the cam out and have it cleaned up and correctly timed. I will make as much power as the power block and be much more origonal.
WTW
03-10-2006 06:34:30
 Re: 40 horsepower with only aluminum pistons? in reply to ET, 03-10-2006 05:08:47
Not to rain on your guys parade but, if you think you are going to get 40 HP out of a stock block with high compression pistons and a altered cam in a model 50 John Deere I got some beach front property for sale in Arizona too. The power block would get you closer than the stock block but it too will not get you 40 HP with a stock crank. I have run several of these size power blocks with and without stroker cranks behind them and know for sure you will never achieve your goal at stock or near stock RPM with a stock stroke crankshaft. Sorry, DW
ET
03-10-2006 09:03:10
 Re: 40 horsepower with only aluminum pistons? in reply to WTW, 03-10-2006 06:34:30
My goal was not to make 40 hp but to end up with a good healthy working tractor. I don't have much use for the pulls.
WTW
03-10-2006 10:15:44
 Re: 40 horsepower with only aluminum pistons? in reply to ET, 03-10-2006 09:03:10
Good working is very achievable. 40 HP not. I would agree. DW
