2020 JD Diesel Sleves
Mechanic Doug
03-09-2006 17:59:03
Dad's old 1966 JD 2020 Diesel's Sleve o-rings finally rotted away and was letting water in the oil, I have it apart and have new parts, Can anyone send me a diagram of the order the o-rings go in or explain how they go. Thanks DOUG
jdemaris
03-10-2006 10:55:38
 Re: 2020 JD Diesel Sleves in reply to Mechanic Doug, 03-09-2006 17:59:03
It depends if it's an early or late block. The early block originally only had one black sealing ring and it was not very reliable. The later, upgraded block has two o-ring grooves in the block and one seal on the sleeve - three all together. For the older engines that do NOT have the grooves in the block, Deere updated with "conversion sleeves" and they have two grooves on the sleeve instead of the block - i.e. three seals per sleeve. With either engine, the orange seal ALWAYS faces the coolant - i.e. the highest one up towards the top. It is made of different material than the black seals, and is supposed to expand once anti-freeze or oil touches it. That is why you get all the warnings about NEVER using oil to lubricate the seals when installing - and only to use hand-soap, if anything.
donmyeil
03-10-2006 07:48:53
if the sleeves come with packings and there is a square one you must grind a bevel on the block,on the top where the o rings go in order to install the third packing. there is a sharp edge that will catch and cut the packing. should be directions with deere sleeves. hope this helps. Don
Bison
03-09-2006 20:29:20
Does this engine has 2 grooves or 3. normally I think they use 2 o rings . The red one goes in the top, the black one in the bottom, If there is a third groove {centre} , that one bleeds to the outside of the block, to let antyfreeze out if it leaks past the o ring.
but these holes clog up over time and don't do what they are supposed to do.That is wy you get water in the oil.
I would put an extra o ring in that groove to.Red or Black, Because the top groove is probably pitted badly.
Make sure you get these grooves spotlessly clean with a scraper of some kind and follow up with a wirewheel in a hand drill or a dremeltool.
Do not clean the hole to the outside.
Ornery job but has to be done. Use plenty of detergent soap with these rings
