Felt Retainer on back axle of JD model 50
Tom/ IA
03-09-2006 09:35:44
Just wondering if I can re-use the retainer after replacing the outer felt washer on the back axle. And what is the best way to take it apart.
F-I-T
03-09-2006 10:05:20
 Re: Felt Retainer on back axle of JD model 50 in reply to Tom/ IA, 03-09-2006 09:35:44
Tom:
You can re-use that retainer as long as you don't beat it up too bad taking it out. As for the "best" way to remove it....the best way is to push the axle out from the inside end and that pushes the retainer out with the bearing.
FYI: If you are looking to cure an end of axle oil leak by changing the felt, that's not the place as the felt is used only to deter dust migrating into the bearing, not to hold oil back. The oil seal is on the inside end of the axle and you have to go in through the read end to remove the bull gear and replace the axle seal. The gear oil that keeps dripping out is that which had already made it past the old oil seal and settled in the big hollow of the housing. If you replace the inner seal, it's a good idea to pull the axle out and wipe the housing clean or that old oil will continue to drip out for a long time, making you think that you didn't seal it correctly.
Just incase that's where you were headed.
Frank
