FIT question about electro plating
Oregonfarmer
03-08-2006 19:04:30
I would like to electro plate and don't know much about it. Could I use a battery charger or a DC power supply?
Lee B
03-09-2006 22:23:34
 Re: FIT question about electro plating in reply to Oregonfarmer, 03-08-2006 19:04:30
Probably neither especially if you mean something that you already have. Plating requires amperage above voltage, something like 1.5 volts at 10 amps depending on how big the piece is that you wanted to immerse into the plating fluid. Handling, storing and expense of plating chemicals make it such as to not be the typical hobby, and far, far cheaper to have bigger items done at a shop unless you are going into the business. Start small and small items might be best done with the pen type kits.
Copper plating must be put on steel with a Cyanide solution in order to get the first few atoms of copper to stick at all, at that point you can switch to copper sulfate solution with a copper electrode and plate the copper up as thick as you want. Copper and especially chrome plate on with microscopic holes going down to the base metal which leads to corrosion and bubbles in the chrome plating which with time will rupture and flake off. One way to defeat this is to first flash with copper, then with gold. Burnish the gold to seal the copper holes and plate the gold with chrome. Gold plates with no holes so water can still get in under the chrome but the gold won't corrode to cause any bubbles in the chrome and the water can't get to the copper holes to corrode the base metal because the gold was burnished over the copper holes effectively sealing them. Neat theory, I wonder if it really works? Ahh, if only I had more time and money...
Glen in TX
03-08-2006 20:28:54
Was recently some discussion on tool talk or someplace here about that. Like Frank said I think you need more than a battery charger to get a good quality plating. I was looking at the cadium plating and black oxide kits recently. You can find more kits and info at Caswell site.
F-I-T
03-08-2006 19:24:16
It depends somewhat on the reagents you intend to use and the base metals you are trying to attach the plating to, as items like the electromtive series becomes important. But...as to the basics, you would use a direct current, such as that provided by a battery charger. However, most electro-platers, (and I am by no means very informed in this area) use higher voltage units, as well as widely variable voltage DC power supplies.
Frank
